razteo
Special Member
Just installed new grips last evening.
I got a set of ProGrip Sport Gel, I cut the OEM ones out, cleaned the bar and the throttle from any old glue, etc, then cleaned even more with rubbing alcohol, then slide the new ones with Hairspray as recommended.
The left side felt glued and strongly planted in minutes, perfect, but the throttle side was rotating around even this morning, after sitting for 12 hours. The size seems fine, but the hairspray doesn’t adhere.
So I left the bike in the garage this morning for that hairspray to cure and I’ll check again this evening, but if is still sliding around this evening, I have no choice but to take it off & glue it to the throttle tube.
I tried to avoid gluing it, but it looks like I may have no choice.
Any suggestions?
Any suggestions?
