killernoodle
Making stuff
I dunno if you guys frequent the "other" FZ6 message board, but I'm about to start custom building stunt cages and race rails for the FZ6. Nobody makes a good sturdy kit for our bikes, so I figured I'd step up to that plate. I still haven't 100% decided on a design for the kit, but here are my ideas:
-The kit will be constructed of 1" diameter thick wall steel tubing.
-There will be several variations of the kit tailored for specific applications. A race rail will be available as a beefier alternative to a frame slider and a more extreme stunt cage will be available for those interested in protection against repeated drops or a wicked get-off at a track.
-The base of my kit will be an FS6 frame slider, mainly because the shape is very easy to integrate into the design and they are inexpensive, not to mention its possible to purchase replacement pucks for them online relatively inexpensively. Also, it would be pretty neat to have the option to be able to take the rails off and just have the sliders, a convertible if you will.
-The main goal of the kits will be to give the frame sliders a much sturdier mounting point that should resist bending and breaking the engine mounts when involved in a slide. The stunt cage will provide additional rigidity and also wrap around the motor in such a way that it protects from curbs and other obstacles when stunting around. A slider doesn't do any good if a simple lowside can fold it up, damaging the frame and letting the pavement contact the engine cases anyway. I know this first hand because the attached image below is what happened to my slider in a low speed parking lot incident and it actually bent my frame out a little bit right there.
Now for the bad part, because I will need to buy a tubing bender and a notcher to make these parts, I have to have a commitment from a lot of people to buy these before I can start making them. A good bender costs approximately $500 with a die set and a notcher costs about $150 for one that is going to last. Theoretically, I could start with the simple race rail and sell a bunch of those before I buy the bender since I could quite easily bend those up with a torch and a vise, but I would still need a commitment from buyers to make it all worth my time.
When I made the extended clutch slave levers a while back, I worked out a pretty good system of taking pre-orders and then purchasing all the supplies I needed to do the project afterwards. I had about 30 people do it this way and it worked out great.
So how many of you are interested in this venture? I'm thinking about charging probably $80 for the simple race rails, powdercoated of course in a choice of colors, the sliders cost about $40 on top of that unless you happen to already own FS6 sliders.
LMK what you guys think. Also, if you want to post a picture of your dream stunt cage, please be my guest. If you want to add extras (light mounts, highway peg mounts, etc) please let me know those details as well.:thumbup:
