- Joined
- Feb 7, 2009
- Messages
- 12,548
- Reaction score
- 1,196
- Points
- 113
- Location
- Cape Coral, Florida, USA
My plan tonight is to empty tank(inspect fuel) and attempt at removing the fuel rail. From initial thoughts, I feel that the fuel was clean from the tank and dirty in the rail, but I shall check that tonight!! Thanks all. Also, the fuel pump filter seems pretty minuscule. I am curious if anyone every puts an aftermarket fuel filter in line with the fuel hose?
Here's a pic of a filthy OEM filter:
Question, how did you drain the tank? Completely drain when the pump was changed(hopefully)?
Re an aftermarket fuel filter. It's not needed and that IS A PRESSURIZED FUEL line you'd be hacking into with WAY MORE pressure than the little screw on clamps are designed to hold.
Once your system is clean and operating properly, no additional filters are necessary.
And to answer your question, no where on this site have I've ever seen of an after-market, ADDITIONAL fuel filter installed.
