2007Z6ALL-LED
Hi,
my 2007 FZ6 was just recently changed the sparkplug NGK CRxx94 (the one recommended used by mostly FZ6 owner).
I suddenly noticed the temperature higher than normal, idle 168 but when/while riding on freeway it gets up & down around 186-198 (occassionally it goes down 186 but eventually 186-192-198 up and down around those numbers).. And If I ride/stop in local it immediately goes up around 202-212 and 217 then the fan kicks in and temp drops down to 198-202 while stop/go in local traffic with fan auto-on/off..
Is this normal to be at this temperature range/behavior like the above? during the time I replaced the sparkplugs, I had just to lower the radiator without disconnecting any hose by opening top and bottom screws of the radiator and put them back in..
I checked the coolant is still top radiator, the reserved tank still at the limit level..etc
anyone's idea will be greatly appreciated!
