Ok, so... I am a cheap kinda guy, so when i decided to go the projector HID route, I did not want to buy 2 separate kits and split them. So I just ordered the H7 Bi-Xenon HID kit and figured that i would live with the low side only for now if i couldn;t figure something out.
Well I have not finished the wiring yet (I am fairly anal about wiring) but here is my start to how I did the physical installation of the Projectors.
Headlight Assembly removed from the bike:
Toss it in the oven at 170 degrees (lowest setting my oven has) for 10-15 minutes:
Pull the headlight apart to separate the lenses from the housing:
Putting the H7 side in was pretty straight forward (remove bulb, slide it in and tighten it down, then replace the bulb):
then came the thought about how to get the small H7 light to sit tightly in the big hole of the H4. So i dissected 2 x H4 bulbs like so:
I then was able to place one on the inside and use it as a washer to stop the projector from going too far into the hole:
Same thing on the back side:
Then just tighten it down and make sure that you physically keep it aligned (since this will not stop the projector from twisting while tightening):
Put the covers back on the housing, Put the housing back on the bike and commence wiring:
as soon as the wiring is done i will post pics of the aiming and obviously the light output of these But so far they look good and they are both in the housing very securely, and i only had to order 1 kit and sacrifice 2 x H4 bulbs.
