The kit really doesn't come with much wiring between the bulbs and ballast so i cant fit the ballasts under the seat as I had originally wanted to.
You can always extend the wires, that is my plan...
Before you go through the effort to extend the wires, test fit everything first to make sure your ballasts fit the way you'd like them to. I made this mistake and ended up having to re-shorten the wires to get it all to fit in the fairing instead.
Don't try to get the ballast into the nose of the bike, it won't fit, i just took the entire front end of my bike apart trying to relocate mine to there, you have the same ballasts that i have and it is a definite no go. I am going under the tank with mine, just have to extend a couple wires and i am good to go, I checked the fit of that tonight too
I'd love to go under the tank with them but I dont fancy buying more things for the mod at the moment. Cutting or doing a DIY extension of those cables can be disasterous...you'll have to buy longer ones. (i'm sure ya know that!!)
O and the H4 works so so well...its fast and BRIGHT!!
People spoke about the splitting of the light because its being put into halogen reflectors...i must have gotten the miracle bulbs because they have the exact same light pattern as the halogens.
I'll be fitting it this weekend so wait for the photo's!
I am extending the wires, not buying longer one, just be sure to solder and tape the wires and use same gauge wire and you should be all set.
I highly recommend using shrink tubing since this will be exposed to moisture from the weather and washing the bike, then follow that with electrical tape if you like. This will ensure you avoid a short later on.
Absolutely vital to use shrink wrap alright! give its a clean finish too!
RSW, how much of the double sided industrial tape did you require on each side? I'll only get the chance to buy it on Saturday and want to know how much and what quality i'll need to keep these ballasts on!
The ballasts have internal igniters installed (the H4 comes with an additional box that aids in the high low change. The power comes from the light wires and not the battery as I said earlier...apparently this is enough to power the ballasts. The guys I bought from are one of the leading companies in the whole of the UK and they make their own units...very high quality! I'm just glad i dont have to fit igniters in an extra place too!!
so what double sided tape did you use or does it really matter?
When you go to the hardware store, just look at your options and get the strongest stuff they have. There should be a tensile strength rating on each package, or just ask someone who works there for help. You'll likely need 2-3 layers on each side, each being about 3 inches long. I suggest just buying a few feet of it to be sure you have enough.
thanks a million!! A simple piece of advice but extremely vital for my simple mind!! :rockon:
I can't wait for pics on here. Really wanna do HID conversion... How'd you get the deal again? Thought I read you got a discount of some sort... really anticipating...
