Had to dial in on adjustment, very comfortable ck out the pictures
damn.. looks comfy... i might just have to look into this more... thanks for the pics :thumbup:
Hello All,
These Givi Engine guards look great but good point. Does anyone know if this guard will block the oil plug from being able to remove it?
And.. would you go with these or the OEM engine guards?
Thanks you for the help.
yeap this guards actually blocks the drain plug and hinders the opening of the oil filter as well.
previously every oil change, i had to dismantle out the crash guard til one fine day seeing all the threading coming out from the main frame. I got pissed.. and emailed GIVI. They asked to go to my local distributor and have it modified. Extending the spacer in between the frames and the mount of the guards. But after extending the spacers, the shaft to the main frames gets too short...
overall i find its pretty much crappy design....
Hello All,
I did have to grind down the drain plug 2 threads to be able to unplug without removing the guard, oil filter has not been a problem
