abraxas
Biker
- Joined
- Oct 10, 2007
- Messages
- 652
- Reaction score
- 5
- Points
- 0
- Location
- South Africa
Following on a similar thread, i now have:
1. 2 Engine mounting bolts, about 8cm longer than the standard.
2. 1 Polyethaline plastic solid tube 65mm wide and about 300mm long.
So all i need now is a lathe to shape the plastic into the correct format.
1 problem i see already is the recess in the frame where the bolts fit in, there's not much space for the slider to fit against the frame tightly. Further than that, how wide should they stick out? How rounded should they be?
Suggestions?
Thanks in advance!!!
Suggestions?
