You should be okay. I mounted a mt03 headlight with fork mounts and have zero issue with ignition clearance. I've seen folks mount round headlights with the eBay brackets as well.
Yeah the cheap ones. Mine are expensive ones, but I've seen plenty of cheap brackets. The thing is the light once you get it installed sits a bit below the ignition and it's a non issue.
