- Joined
- Feb 7, 2009
- Messages
- 12,550
- Reaction score
- 1,199
- Points
- 113
- Location
- Cape Coral, Florida, USA
no need to be like that guy..im just trying to make sure all of my bases are covered, before i do any unnecessary modifications..i am pretty sure splicing the kill switch will fix it from what everyone has described i just need the time to do it..ill try the fix and get back with yall..
I wasn't trying to come across being nasty, if it did I apoligize. Motogiro and myself gave the most likely reason for you your problem however, per your posts, its still happening without trying any of the fixes... Making a jumper cable (post #33) will not modify the bike what so ever and can be removed. A new switch can be replaced if needed/wanted once its determined to be your problem. Yes, it will take some time to make a jumper cable and then to install it. I don't know have any other recomendations/ideas. The shop might be be the next stop.. Should it be, please post what the problem actually was so I can learn from it...
Perhaps Alanrim knows the fix. Can you help as the bike's still not running right?
