- Joined
- Feb 7, 2009
- Messages
- 12,538
- Reaction score
- 1,185
- Points
- 113
- Location
- Cape Coral, Florida, USA
Sounds like the fuel might be shutting off. Could be a bad/intermettent fuel pump relay or fuel pump. Lift tank and check all connectors. Do you have anti theft that might control the fuel pump relay?
S107, did you check this relay? Can you hear the fuel pump when you first turn the key on? If not, your not getting 12 volts to the pump (either the relay or ECU/wiring problem). You can disconnect the pump harness at the pump and put a volt meter on it. You should have 12 volts. Sounds like your getting the initial 12 volts to prime the fuel system (that's why it runs for 3 seconds-from the fuel in the system, then it runs out of gas).
Someone, not too long ago had a similar problem, I believe their problem was replacing the fuel pump, do a search, it was within the last month or so...
