ECU pin broke off, stuck in connector
bababababa
Germany
Hey all,
I unplugged my ECU recently to look for what I thought was a faulty wire, and it turns out one of the pins was corroded, snapped off and is now stuck in the connector. I found a company that says they can repair the pin on the ECU, so now I just need to get the broken off pin out of the connector and I'd be good. It broke of completely flush with the connector surface, so there's nothing I could hold onto with pliers or anything. Is there a way to disassemble the connector and get at it from the inside or something, or am I gonna have to replace the wiring harness?
Edit: Oh yeah, I'm talking about a 2007 FZ6 RJ14...
Any hints would be awesome!
You should be able to put a small sewing needle or similar from the "backside" of the larger connector.
Those wires have a little "tab" that once pushed in, the entire wire can be pulled out from the rear. Once that's out, your broken ECU end should fall out..
A picture from a Honda:Capture.JPG
