RedFZ6
Woow, That looks REALLY bad
Good luck
Good luck
Easy fix to your problem. I have one of those oil filter cap wrenches the one that fits over the filter. I had one heck of a time getting the filter off it just kept slipping, so I took a 5/16 inch self drilling screw and drilled it through the cap and filter. Then just backed the filter off with out any oil comming from the filter. The next time I had to change the oil I just used the same hole with a self drilling screw and the filter just back off with out a hitch. Good luck. :cheer:
Doc
truth.
self tapping screw a filter wrench onto the filter and your good to go
Wait, you mean drill the screw through the wrench into what's left of the filter?
It seems like if I did that, it would just destroy the filter more when I tried to turn it. Maybe I'm just not understanding.
I think these guys may not be understanding that you have almost no filter left.
Do you feel confident proceeding without damaging your block where the gasket seals or the threads that the filter threads onto? If not, see if you can talk a local m/c mechanic into coming over to your house to give it a shot, or truck your bike into a shop.
If you do feel confident, it seems like gently trying to break the seal free and/or gain purchase on what's left of the filter to unscrew it is your way to go. If it were me, I would tap a notch into the outer edge of the filter with a screwdriver and a hammer. Then using that notch I would put the screwdriver at a 45 degree angle to the filter and tap counterclockwise with a hammer to nudge it free. You probably have a good amount of crimped metal left on the filter housing to do this without damaging the block. Just make sure when making your notch that you don't punch through the remainder of the filter and gouge your block.
That is exactly what I would try based on the pictures. Or it may be time to make a tool. those holes in the filter base...how deep are they?
So how did it go sanguines? I'm curious to know how this turned out. All is well I hope.
Unfortunately the bike is still sitting in the garage, busted. I've been working on it when I get a chance, trying to use a hammer and screwdriver to carefully tap it loose, but no luck so far. Frustrating. I don't have very many tools so I haven't been able to try some of the other suggestions. Fan clutch wrenches are pricey, too.
