Scotteh20
I bought both the H4 and H7 kits last night. I was able to get the H4 kit installed and it fits fine. The vents for the cooling are partially covered, but I would say that they are still open at least 50%.
Unfortunately, due to how far in the H7 lights needs to be pushed in and twisted to lock it into place, I was not able to install it with the rubber boot to seal the enclosure. It does install like the other poster mentioned without the boot, but even then there isn't really any extra clearance for the wire that comes out of the LED housing at the back. I tried modifying the boot by cutting some of the portion of it out that sticks in towards the housing, which would still allow for a seal, but it did not work for me. I felt like I was maybe able to push it in to get it seeted and twisted it to lock it into place, but it just wouldn't hold.
Also, when it's installed without the rubber boot, it's clear that the LED light's housing is heavier which seems like it strains the clip that secures the headlight bulb. I believe the clip would be fine, but it actually doesn't even push the top of the plastic shroud that goes around the LED housing and clips into place to hold it in the headlamp housing.
BTW, I have an '07 with the BD43 dual headlight mod installed. I decided to go for a ride with both installed, the left side without the rubber boot of course, to see how they performed. I can say that I love the color of the light they produce. I think they look fantastic. Unfortunately, They did not "light up the roadway" as well as I was hoping. I believe this is due to how they are reflecting within the headlamp housing though.
Long story short, the H4 will install with the rubber boot and no modification, but a portion of the vents are covered. I could not get the H7 installed with the rubber boot, even with some modification. The way the light reflects from the housing onto the roadway left me wanting more light. I had 1 other driver out of about 30 flash their high beams at me when I was running my low beams. I truly wish these worked with the FZ6 as more of a plug and play, but it just doesn't seem they they are. I'm not sure yet what I'll do. I'm leaning towards returning them and going back to halogen bulbs so that I can see the roadway better at night. I'm not a big fan of not having the left side without the rubber boot either. I'll leave them in for a few weeks to see if I change my mind.
