ErikNYC
I want one for my 06 Fazer..
Same here!
We should organise a group purchase if the production resumes. I think it will cost us a bit less for freight :thumbup:
OK, I don't know if this thread went elsewhere but I got tired of waiting and got a friend who has a welder to add 10mm to the slave clutch lever. It's rough and ready (I did the grinding) and we just sprayed it with black paint but it works a treat.
i'm definitely interested in a run. the stiff clutch has been just about my only complaint since i got this bike. is the core lever available from a parts supplier? unless this is a winter time run i don't want to have the bike down for too long.
I meant that the stock clutch setup will be faster than a setup with the modified slave lever. The modified one increases the "friction zone" which is good if you want to work the clutch for city diving, or if you want an easier pull, but the increased size of the friction zone means that the clutch slips a bit more when you're trying to get on the throttle. That said, it's not THAT big of a difference in performance.What do you mean? Use the clutch, but without the slave lever?
The p.o. said he kept the cable lubed. I'll have to see how it's done and give it a try. How do you direct oil down the cable?
Before you buy, try lubing the clutch cable with engine oil. The clutch pull can be hard on our bike, but it's nothing that isn't manageable when lubed up. And besides, it's technically much faster to shift (when using the clutch) if you don't have the slave lever.
Before you buy, try lubing the clutch cable with engine oil. The clutch pull can be hard on our bike, but it's nothing that isn't manageable when lubed up. And besides, it's technically much faster to shift (when using the clutch) if you don't have the slave lever. :rockon:
Any idea on another run? My bike has sat for a few months and the clutch is rock hard. I might have to pull it apart and lube every section separately. But it's got like a 50lb pull force now. It's always been bad, but now it's very bad.
Just a feeler here, is anyone still interested in these? I have some free time and a new shop.
