2006 left side does not flash on turn mode
MrMatty8
Mountain Top PA
2006 FZ6
Dropped by previous owner on left side
Cant get the left turn signals to flash???
What should I be looking for? Thank you in advance, Matty
Very, very likely one the left side directional bulbs broke a filament.
Replace the bulbs one at a time...
Also, you can remove the yellow cover, pull the bulb and very likely see the filament broke off..
MrMatty8
Mountain Top PA
Thank you I just got in from work it's a bike I just bought for my son I will look at it 1st thing tomorrow I appreciate the information
MrMatty8
Mountain Top PA
Thank you very much. I just got in from work. Too beat to look at it tonight. It's been raining here non stop. NE PA. .....
[email protected]
I am also trying to remove the front wheel so I can put a new tire on. What size is the front axlenut ?? Th again. Matty
Ohendo
Downingtown, PA
I believe it takes a 19mm Spindle.
Alternatively, what I use (thanks to this forum) is a 5/8 spark plug socket . Stick an extension in the 'wrong' side and you're in business. You may have to remove the rubber boot from the spark plug socket that helps to hold spark plugs in place.
