Ohendo
NP!
Report back your throughts on the drawing that comes with them!
Keeping in mind that a small 9volt battery will power them on to defend what should be obvious in their drawing. lol
Black is ground and the supplied load resistors are for blinkers only. So if you have an electronic flasher relay, you don't need the load resistors. :thumbup:
Damn it... The bug bit me.
I went ahead and ordered the rear signals also. Probably could have saved some dough if I'd ordered together as you did. Oh well! Should be a fun few hours hooking them all up. Also ordered some splitters to be able to use both the signal-integrated tail light and these signals.
Still not sure how I'll tie into the connector for the tail/brake light. Can't seem to find a splitter for that connector. Hoping the solution will be evident once I get into it.
Sent from my iPhone using Tapatalk Pro
