Can't shift - Need help
cmantis
USA
Half way home my clutch became useless. I was able to get home with a combo of shutting it down at stops. I found the culprit to be that the guide for the clutch cable isnt bolted in place. So when i pull the clutch in the cable is rising up rather than pulling in. Looks like im missing a bolt.
Any help, please and thank you, identifying what size and length bolt?
* look just to the right of the spring
If it can't be fixed with a hammer, it's electrical. Good call Cliff. You could have also got home by not using the clutch at all. Very easy going up the box. Needs practice going down. Great post, first failure I've seen.
Sent from my HTC One using Tapatalk
