My first track day is two weeks away and I'm starting to get itchy. Peg feelers, center stand removed. What else? Got my painter's tape, safety wires, etc. Lots of good info here, but I feel like I should be doing more to the bike.
What kind of shape are your tires in? How many miles / how old?
Do the normal fluids check. Check for leaks. Safety wiring is typically not required for intro / beginner groups.
You may want to pull headlight fuse for the track. My bulbs burned out 1st time out.. I'm thinking it was the extra heat, due to masking tape.
You're going to want to drop the pressure to at most 30/30 (good starting point).
If you've got time, it's always a good idea to check all the fasteners.. make sure nothing is loose.
