fox426
I have pushed started many carb vehicles but what is the drill, sequence for a a fuel injected bike like ours?
I've only had to do this once. Thankfully there was a slight downhill in the parking lot and I was able to do it while on the bike. I used 1st. I believe there is logical reasoning in using 2nd, but I can't recall what it is.
turn it on, check kill switch is set to run, put the bike in 2nd gear, clutch in, run and release!
One thing I'll add, if the battery is completely dead (i.e. nothing even comes on/lights up) it is a pain to get it going on flat ground. If you have a friend to help you push, it's doable. On your own, you're better off pulling the tank and boosting it.
Yup, this is the way to do it. Unfortunately, I've had to do it many times.
One thing I'll add, if the battery is completely dead (i.e. nothing even comes on/lights up) it is a pain to get it going on flat ground. If you have a friend to help you push, it's doable. On your own, you're better off pulling the tank and boosting it. If it's just borderline dead (lights come on, but not enough power to turn the starter), it'll start near instantly with a quick bump.
You just gave me a great idea - modify the cigarette outlet connector I got with the battery tender to have bare leads. Store this under the seat. If a jump is necessary, just hook up the connector to the tender connection and go!
If the battery is completely dead there won't be enough power to prime the fuel injectors
The only thing you might need to be mindful of is that the tender leads are for a long slow current delivery for a battery recharge, the power leads for starting is heavier guage, yes? Someone correct me if I'm wrong but couldn't you actually melt the tender wiring by pulling the neccesary current to start the bike, or would it fire up so quick as to not really make heat generation an issue?
Must admit I forgot about the fuse, I have a 30 amp in line so it will still blow witha direct short but not for a reasonable draw. Still I only use this hot connection for the tender not for running any accessoriesI believe you're right but the in-line fuse would blow first, if it had one and was retained.
My tender had two battery attachment leads that hook up via a connector to the main lead from the tender
one of these attachment leads has circular terninal connectors to enable hooking permanently into my wiring the other attachment has clips but they are for connecting to the battery if its easy to get to or out of the bike. I use this on my sons VTR 250 with the battery accessible under the seat.
