The Dude
abides
When someone makes a left turn in front of you (failure to yield), do you bother using your horn? To simplify, let’s include cars pulling out in front of you from a side street as well. I’ve had this happen countless times, and as best I can recall, I always lay on the horn as I perform my emergency maneuver. What typically follows is the other motorist suddenly looking at me in panic and stabbing the brake. I wonder if I’m actually making the situation worse by using my horn? Does honking just compound the problem by causing the driver to make a panic stop right in front of me? Should I forget the horn in hopes of the other vehicle being more likely to clear my path of travel and reduce the chances of collision?
