Mississippi
Parts:
1st and 2nd pic - rear signals
3rd pic - front signals
4th pic - flasher relay
Problem:
When I use these signals with my original flasher, the flash rate is obviously fast. However, when I plug in the flasher control, the front signals flash at the correct speed. The back signals also flash at the correct speed, but only 3 or 4 of the led’s on either side will flash.
Is the flasher reducing the load to much? Do I need to go with resistors instead of the flasher relay and use a different size resistors in the front and back? Any ideas?
Problem:
