daredevil27
Hey, guys I’ve got a bit of an issue. I own had '07 FZ6. Recently my bike has been stalling a $hit ton. The first time it did this was the end of last season. I put it away and then brought it back out for this season. After I brought it out it started stalling at least once anytime I took it anywhere. For the last month it stopped and hasn’t done it once. Now this week it has started and its worse than ever.
Okay so it seems as if it’s one of two things. Either there could be water in the tank and it stalls from failing to combust or maybe it’s an electrical error by the ignition button and kill switch.
Sometime when I start it, it’ll idle for a moment and then die, but it doesn’t always do this, or I can rev it to 14K and it’ll just die. When I ride it and it stalls sometime it just jolts, like ill be going and then all power is lost and then it'll kick back in, or it’ll die altogether. Sometimes if I rev it stalls and then it'll kick back in around 1k rpms before it re-engages. This morning I stopped at a stop sign and of course it stalled. I pulled the clutch and hit the ignition and nothing happened. I then turned it off and then on again still nothing. So I hit the ignition box and then it worked??? Its most likely to stall when I’m in second in the 30's through town. Once I get on the highway its usually fine but yesterday I was doing 80 @ 8K rpms and it stalled wtf. So I then pull the clutch kill start and continue on every time. I thought maybe I’d be a Throttle Control Sensor issue but that was on typically on the older models again it’s an '07.
The shop would have to diagnose and they charge $70 per hr. So any advice or help would be greatly appreciated. If you need more info just let me know, thanks.
