MrMatty8
I have been looking at Partzilla and it appears as though the housing is available but not the wire which is what I need. I purchased a 2006 FZ6 for my son that was dropped at some point by a previous owner. They thought is was a relay problem. I checked and by process of elimination the left front turn signal stock and or wires are damaged and do not work. I switched the right front turn signal and it works perfect so this tells me that it is the turn signal assembly itself on the left side. All points of consideration are being mentioned from the sitting position on the bike. So sitting on the bike the left front turn signal stock, and wire need to be replaced. Where do I look to purchase them? I need help. I only think they are selling the turn signal assembly with out the wires if I order from Partzilla and any other company. Am I correct? Where can I get what I need? Thank you in advance. MrMatt
