fazil
Hello all,
Today while i was swapping Fz7 clutch slave lever, i came across a loose clutch cable. Checked the slave lever spring and cable freeplay but it seems like there should be an other tension directly coming from clutch basket via clutch release shaft that the slave lever is connected to.
That clutch shaft has no tension an can rotate freely around 15 degrees in directions with hand. So is it normal?
Do i have to take out the clutch basket and check what might happened inside?
Do i need a new clutch basket gasket later?
An do i have to pour out all the oil?
No tension in this shaft, is it normal?
