throttle lock
mikebike
just a rider
North Central Florida
www.crazyguyonabike.com
looking for a throttle lock for the FZ6
I am not interested in the $100 plus of the throttlemeister
just a simple mechanical throttle lock for use on the highway
anybody using one
what make model will work on the FZ6
thanks
MIke
tolgatt
Goodfella
Windsor , ON
i used to use vistacruise on my vstrom,,i was pretty happy about it,,,,i think this weekend im gonna put it on to the FZ6 and see how it works....it is $46 over here in windsor,,,,you might even get it cheaper over there,,,,i will let you know as soon as i install it,,will post a pic too of course
i think it is a must on a motorcycle if you are regularly riding your bike more than an hour...even for couple of minutes resting your right hand is like heaven on the highway.....
H
HavBlue
Ever thought about using an O Ring? It's not enough to keep you from twisting the throttle manually but it offers enough resistance to hold it there while you cruise down the road. Keep in mind, you will have to move it back to the stop to shut it down manually as well.
Hellgate
Moto Demi-God
AUSTX
I'm intrigued. How? Is it used like a "cramp buster" or slipped in between the grip and handlebar?
I agree, that sounds like a great idea, inexpensive and effective. I have the foam grips, I wonder it they would work, or if I'd have to go back to a rubber grip?
H
HavBlue
You'll have to play around to find the right size but it sits on the inside of the grip and when you need it simply roll it over and into the gap between the switch mount and the grip. The O ring will hold the throttle in place until you manually pull the throttle back to the stop. Great for the long haul on the super slab but don't even think about using it anywhere else.
