TB Stock Base-line
galen
Ocracoke,NC USA
I just installed a slip-on exhaust and cant stop the LOPE-LOPE at idle. I have synced the Throttle bodies and idle X2. My #1 TB screw had noticable tool marks(to big driver) so i think i am starting at the wrong point. From what i can tell with checking every thing most of the normal maintenance was not kept upto par. I have a motion-pro carbsynce and a vacume gauge. How do you set cyl.#1 to spec?(06) Do you Gauge #1 and balance the others at the same time or close 2-4 and set#1:confused: It runs good except at idle to 4k. I am running a K&N filter and airbox mod. Thanks for any input:thumbup:
krid80
journeyman of epic status
Festus, MO, USA
www.surdykeharley.com
Just make them all equal on a sync tool. You don't have to set them to a specific setting as long as they are all the same. you will need to adjust your idle when you are done and it should cure the issue. The lopey idle is due to low backpressure. Getting that to permanently disappear may not be possible. But it shouldn't affect anything above idle.
Sent from my HTC EVO 4G using Tapatalk
Whats the idle speed? Bump that to 1350 0r so and then sync them. It should make it easier too. You might also check for exhaust leaks too.
joe1971
Havre
joe1971
Havre
Ok didn't know you had the service manual :thumbup:
By turning the air adjustment screw either direction until 8.5-9in of mercury is achieved (since you already attempted this once I'm assuming that you are familiar with where thing are located and what they are)
set #1 then hook up you nanometer to #1 and using that as a baseline adjust the others to match, I don't know if you have a 2 place nanometer or a 4 place, if 2 then you will leave it hooked to#1 the entire time and move the other hose to 2,3,4, if you have a 4 place then just hook all 4 hoses up and play with it till you get them all to match #1
Fair warning it can get a little maddening some times as when you change one air screw then the others move if you have the fluid type nanometer, so patience is a must.
galen
Ocracoke,NC USA
I set #1 to spec with vacume gauge closer to 9 (spec 8.58...)and matched others and set idel to 1260-1320.It sounded better at first but after a ride it was still jumping from 1220-1400rpm at ideal. Ihave done this 4 times in two days and dont care about the sound any more but i dont want to do any damage. Thanks for the input.
joe1971
Havre
you may want to try getting an unmodified airbox lid, I know the way some of them get modified it causes problem with the intake resonance. just a thought
galen
Ocracoke,NC USA
I was thinking about tapeing it up to see if it made any diff. When i cut the airbox i just inlarged the opening a little on each side. Thanks for the idea,
