Tanks Pads
Sith Lord
Canberra, Australia
What's available? I'm considering getting a set for the sides of the tank (and the regular centre one). I've heard of the Tech Spec (but not seen many pics). What else is there?
Post up pics if you can
Erci
Howie Mandel's evil twin
Pittsford, VT
TechSpec is very grippy. It's thick and quite heavy. Works very well.
pic from their site:
Another popular option is StompGrip: (my R6)
This one is light and transparent. Knobs are very aggressive and grippy. I would think twice about these if I wore regular jeans for riding. I think they may eat through fabric over time.
Carlos840
Belgium
Do you find it really makes a difference while riding?
I have wanted some of those side pads for ages but never really felt like i was lacking grip on my tank. It's a kind of "i want it because i can, not because i need it" thing.
But then when i think of the difference a set of grippy pegs and bar grips did this can only help!
Erci
Pittsford, VT
It makes a tremendous difference in certain situations.
Do you squeeze the tank with your knees when you brake hard? This is where the pads (or even a tank bra) help a lot.
If you slide of the seat at all into turns, they help a great deal.
ltdillard
commutaholic
Texas (D/FW)
I like the TechSpec products from what I saw on their website.
Not to derail the thread, but PO had a center tank protector, but IMHO it is mounted too high. What does one use to safely remove it? I have hear Goo-Gone works well, but don't have personal experience using it, especially on a painted surface. Does anyone have a recommendation?
Tom
Erci
Pittsford, VT
Tom
Start by heating it up a bit. Heat gun on low setting or even blow drying on high will work. Keep heating up until you can relatively easily dig your nail under one corner. You should be able to pull the whole thing off and leave very little residue.
If any residue remains, googone works great.. just be sure to use very soft cloth, wash googone off with soapy water and then you may wanna wax it.
Carlos840
Belgium
I do grip the tank when breaking hard but i don't really slide at all, i guess my legs are pretty strong...
In turns i do slide a cheek off the seat ( if there is a need for it), but i feel like in that position most of my weight is on the outer peg and i don't really feel like my knee needs much help holding on the tank.
This is why i went with aluminium pegs, i always felt like my foot was going to slide of.
Not sure i need them grip pads, but i do know i want them!
Erci
Pittsford, VT
Your weight is in the right place (outside peg). What's locking you in that position? How do you pull yourself back or over to the other side?
Carlos840
Belgium
I usually just use my inner leg to push myself back to center position once i exit the turn...
I use the Tech Spec for my tank sides and a generic CF type tank pad.
Good grip!
Erci
Pittsford, VT
If you're using your inner leg, you're weighing your inside peg. Not ideal.
Outside thigh should be used to pull yourself back or to the other side. And what's the point of contact of the outside leg? Yup!.. the indentation in the tank where the grippy pad goes :D
Carlos840
Belgium
I usually using my inner leg once the turn is over and i am back straight, not sure it makes a difference...
Thanks anyway, I will try to experiment and analyse what i am doing a bit more.
Erci
Pittsford, VT
At street speeds and one corner at a time situations, no big deal. At *spirited* speeds going through chicane (when you complete one turn and want to set up for the next as fast as possible), you want to slide across the seat using outside leg, without weighing pegs and with no input to the handlebar.
Sit a bit farther back in the seat, or you will likely be pivoting around the tank instead of sliding side to side.
It's very fun to practice this.. doesn't need to be at high speed and you don't need to slide off a lot.
To bring this all back to original post. The technique mentioned above is where those side tank pads help a great deal!
Sith Lord
Canberra, Australia
I love mine. For the rear of the tank, I ordered one from them (rectangular) and cut it down some:
That's a Tech Spec as well is it? It does look good. How thick is it?
Not too keen on those Stompgrips. As Erci said, a bit too knobbly for me I reckon.
They're the main two I'm hearing about. Tech Specs seem the way too go, but very pricey. I wonder if I could just buy some rubber from a rubber shop and glue it down somehow?
Erci
Pittsford, VT
No doubt you could. The nice thing about TechSpec is that if you install it properly (very clean tank) you can remove them and re-install them. No residue.
.125"
Yamaha FZ6 04-10 Snake Skin
I really, really like these, fit perfect, well worth the investment IMHO. For something so obvious to the bike, I wouldn't cheap out on it...
Carlos840
Belgium
mmmm, you might have convinced me to get some! And i though my modding frenzy was finished...
