Ryan T
P.P.P.P.P.P
Hope someone here can help me with this issue. I will try to make this as short as possible.
All the tail lights come on when I turn on my motorcycle, signal lights work fine as well. However, when I pull the hand brake or use the foot brake, the tail light does not brighten, it stays low, as if neither brake was engaged. At first, I thought the brake filament in the bulb was burned out, I changed the bulb, no result. I checked the fuses, they all are good (not to mention the tail light is on, it just will not become bright when the brakes are used).
This is not the "brake light is always on issue". It is a "brake light does not illuminate brighter when the brakes are engaged."
Any and all help is greatly appreciated. Thanks
