JasonB
Evening all,
Need some advice on the correct fitment of my new to me scorpion stainless steel exhaust system.
The OEM link pipe has an internal diameter of 50mm, the replacement scorpion pipe is 45mm.
The outer diameter of the OEM cat pipe at the tip is 45mm, however there appears to be some kind of copper wrap on the end of the cat pipe which increases the diameter to 50mm. This means that the scorpion link pipe won't currently fit the cat pipe unless I remove this wrap or replace the cat pipe.
I've attached an image of the cat pipe and wrap. What do you guys n girls think? Can/should the wrap be removed?
What are my options for fitting this link pipe? It came off another 2005 fz6 apparently but I don't know if the PO used a decat pipe or removed this wrap himself.
