8-oji
While switching the OEM brake lines over to stainless steel ones, the master cylinder is mounted high enough where I cant get a torque wrench in there to tighten the banjo bolt. So the right side rearset was removed and the brake line bolt was tightened to spec. After scouring over the service manual and the forum, I can't seem to find the torque specs for the rearsets. The installations that for aftermarket ones don't mention anything either. Does anyone have the torque info for the bolts that mount the rearset to the frame?
Thanks in advance :thumbup:
