Rear brake light switch
Bikebiz
Sydney
I needed to adjust my rear brake pedal position with the clevis. As such, it's changed the point at which the switch activates the brake light. Luckily taking more movement to activate than less.
Any tips on adjusting the switch? I haven't had a chance to pull the rearset plate off entirely to have a good look. I'm hoping I can just loosen the screw holding the switch housing, then raise it to increase the spring tension.....
Australia
I reckon you are on the ball there...
:thumbup:
