Need help
Slater
Idaho
when cornering fast my bike feels like the shocks are to soft and the bike sinks to much than causes a slipping feeling is there a way to ajust the shocks '
didnt get a owners manual with it so have no clue
Dennis in NH
Southern NH
How much do you weigh?
Many of us have upgraded the front springs and fork oil. A higher rated spring will support more weight and reduce dive. Getting thicker fork oil will improve compression and rebound.
As already mentioned, first try the rear preload and hope it gets better (at least for now).
Dennis
Slater
Idaho
weigh 222lbs
what ever i need to do i will may take time to get if takes alot of cash so the least expensive the better if i have to change out what should i go with so i can add it to may huge list of mods may put in second spot so want my two brothers first lol
Dennis in NH
Southern NH
Increase the rear preload for sure -- if you haven't already done so.
Fork oil is pretty cheap -- check with your local dealer. It's just a little work intensive (time wise) -- not really that hard. You just need to get the front end off the ground.
Leaning back a little on hard braking can help reduce front end dive.
Dennis
