Plymothian
2004 Fz6
Hi everyone,
had a couple of intermittent problems and wondering if you can help.
Firstly, every few days or so i go to start the bike and I press the button and nothing happens. If I turn the ignition off, then on again, it starts up fine. Only does this occasionally and has happened both in the wet and in the dry.
Second problem: I turned the bike off last night and all the lights went off as usual, but when I locked the steering and pulled the key out, the lights came on and stayed on. Similar to problem above, when I turn ignition on, then off again, the problem is fixed. No other lights come on, just the tail light and side lights (and the one front light).
I think the battery is a bit low (getting charger this weekend) but don't think this would affect these two problems? It's still under warranty but wanted to see what people thought before I possibly get a "they all do that" from the dealer!
thanks
Hi everyone,
thanks
