mglowe
- Joined
- Jun 6, 2007
- Messages
- 405
- Reaction score
- 1
- Points
- 0
- Location
- Ames, IA USA
Hello all.
Here is my installation of the "Kaoko Throttle Control"
I installed this on my 2007 FZ6 so I can only assume it will be the same for other year models. I did this, with taking pictures, under 30 minutes and I will bet anyone could do this under 15 minutes if you have everything ready.
Oh yes... I cannot be held responsible for you or your bike - you assume all risks.
Items used :
- Kaoko Throttle Control
- Drive Ratchet
- Extension Bar (optional)
- 8mm Hex Bit Socket
- 10mm Hex Bit Socket
- Torque Wrench
- Thread Lock - Blue (WARNING: DO NOT USE RED)
- Grease (optional)
What I did :
Remove the throttle side bar end with 8mm Hex Bit. My bar end took no effort to un-screw and the extension was not needed.
Note: There is difference in design from the factory bar end. I was not able to weigh the Kaoko against the original as I did not have a weigh scale - sorry.
Install washer.
Remove the friction nut to put some grease on only the friction nut threads.
Put some thread lock on the other threads.
Install with the 10mm Hex Bit and according to service manual torque to 19 foot lbs.
Really simple to install and looks looks good.
Items used :
- Drive Ratchet
- Torque Wrench
- Grease (optional)
What I did :
Install washer.
