Thanks, i meant on the bike though... There are not a whole lot of chrome parts on the bike and i was curious if it stuck out like a sore thumb, or added a tasteful touch of "Bling"
KN-303 or the chrome one is KN-303C
Watch your year of manufacture. The UK site quotes KN-204/C for 2007 models.
Is there something I'm missing....I remove the oil filter with an oil filter wrench I bought at advanced auto parts.
And me too..it saves knackering my screw drivers.
This method always used to be frowned upon. I don`t know if that is still the case.
Steve
good catch, thank you.... I thought they were the same engine? Just different FI Maps?
I just read on a site that the KN-204 does not have a pressure relief valve.
Anyone know why it would be recommended for the 07?
Many full-flow filters use an integrated pressure relief valve to allow for a bypass mode. If the filter element becomes completely clogged, the relief valve allows oil to bypass the filter thus protecting the engine from an oil starvation condition. Another thing to think about is the valve may also open in very cold conditions allowing for increased flow. I run a filter on the Harley that has no by-pass and it wouldn't bother me to have one on the FZ6 as it is not likely that in 1,500 miles the oil could become so contaminated the filter would need to use the by-pass. Now, if I never changed my oil or ran really high mileage intervals between changes I would be using a by-pass filter for sure.
This is what I use to remove and install the oil filter.....
AutoZone.com | Shopping | Accessories | Product Detail - OEM 65 to 67 mm. dia. Oil Filter "F" Cap Wrench
When I changed the oil on my 06 for the first time after buying it...it was obvious that: it was way over tightened; had not been off for a bit. Tried 3/8 adaptor type= just spun, strap type= spun. Got out trusty screw-driver= came off. Put on K&N with the nut on the end= should come off easily next time around...........I hope.
