^ Thanks! I may take you up on that!
Actually, if you can pick up some thin ALUMINUM plate, 1/16" or so it would absorb and radiate the heat a little faster than sheet metal. Aluminum that thin can be easily bent in a vise or by hand. Your shield will likely be a semi circular which you could easily bend around some approx 1.75" tube (just slightly larger diameter than the stock pipe..
You could also pop rivet an additonal small "air scoop" to it to pull air thru and past it, out the back of the bike...
The second attached photo is a lock bracket made of thin aluminum (for an FJR), made by hand. All bends are made in a vise, with a square, block of wood and BFH. Its very easy to work with.
The first is again made by hand and is 1/8" aluminum. Considerable stiffer, workable but overkill for what you need.. (Concours helmet lock bracket)
