sleepymas
My headlight stopped working the other night on a ride home. i have checked circuts and found that i can jump the relay and they work just like they should. so i found that the relay is not being commanded on by the ecu. i can ground the control circut of the ecu and the lights come on like normal. does anyone know or know where i can get a decent circut description for the lights. i need to know if the ecu automatically turns them on with key on, or if the ecu needs an input to turn light on. really dont want to blow money on an ecu just for a headlight... i will probably just make a jumper switch to ground that wire instead, but before i ghetto rig it i want to be sure that the ecu is the problem.
