Slater
are there any mods to improve handling?
Suspension. A set of Racetech springs in the front will make quite a bit of diff on the FZ.
About the tires, BT016s are awesome for the street. Sticky, but they won't last too long
No, this is not normal on the FZ6... and quite dangerous too
I would look at the following in this order:
- steering head bearing (search this forum for threads about how to check them without tearing the front end apart)
- front axle and rotors (is the axle properly installed with all proper gaskets and shims? are the rotors bent out of shape?...)
- fork oil/springs/seals...
any recommendations on the tires i should put on?
hi guys .i have a small problem. do help me out on this. after reach 180 to 190km/h my bike start to wobble on the front. do you guys have this issue as well? anyone have this issue and aready solve this ?thankyou so much for your help . cheers
