handlebar grips
mave2911
South Australia
OURY recommend against using hairspray as the solvents can break down their grips.
There are many 'rubber safe' adhesives out there, and they offer the added benefit of giving you more time to seat the grip.
Cheers,
Rick
Erci
Howie Mandel's evil twin
Pittsford, VT
If you've gotta air compressor, it makes removal infinitely easier. Same goes for install.. I've never had to use any spray to get them back on.
A metal coat hanger cut to form a crank shaft works great. Its basically an 8 gauge wire (no flat spot to damage the throttle grip like a screw driver). You slip it in, and start cranking it and winds its way around the grip. Add some detergent and give it a pull.
I recommend cleaning the grips inside to ensure the mold release agent is removed so they stay put.
I sprayed some semi gloss spray paint into the grip and slid it on. In 20 minutes it seemed strong and left on a ride. It never moved.
ChevyFazer
Redneck MacGyver
ATL
I've always just cut the old grips off, but for putting the new ones on I tried windex last time and it worked great, slipped right on and the ammonia dried it right up and stuck like glue.
As long as the grips aren't glued, the air compressor with a fine tip (as noted above) works wonderful.. No muss, no fuss...
No chance of tearing a grip (done that with a screwdriver/wire), keep the air flowing high and manipulate the grip on or off..
Same if putting on foam "Grip puppies"...
