04fizzer
I'm in the process of picking out the bits for my first build. I tend to research the crap out of things before doing it, so bare with me on this.
Here's what I'm looking at getting:
Lower
Spikes Tactical stripped lower (already have this)
PSA Classic LPK w/o FCG PSA AR15 Lower - Lower Receivers - Lower Parts - AR-15
(one of the following)
Bushmaster Competition Trigger Kit Competition Trigger Kit AR-15 Matte
RRA Match 2-stage trigger - standard PK Firearms | Online Store
AR-15 Non-Adjustable Trigger Kit (JARD) AR-15 NON-ADJUSTABLE TRIGGER KIT - Brownells
Del-Ton 2-stage combat trigger assembly Two Stage Combat Trigger Assembly AR-15 AR-10 LR-308 Small Pin .154 Matte
A2 Rifle Stock Completion Kit AR-15/M16 STOCK COMPLETION KITS - Brownells
MOE Rifle Stock (Magpul) FIXED & PRECISION ADJUSTABLE STOCKS – AR15/M16 Type Rifles, FN FAL, HK G3 - MOE® Rifle Stock
Upper
Spikes Tactical Upper M4 Flat Top Upper Receiver - Forged M4 Flat Top (Multi Cal) [SFT50M4] - $115.00 : Spikes Tactical
Spikes Tactical Bolt/Carrier Set AR-15/M16 BOLT & CARRIER SETS - Brownells
BCM Charging Handle, Medium AR-15/M16/AR .308 BCM GUNFIGHTER CHARGING HANDLE - Brownells
SI Defense Barrel AR-15 5.56x45mm NATO 18" HBAR Contour 1 in 8" Twist Matte SI Defense Barrel AR-15 5.56x45mm NATO 18" HBAR Contour 1 in 8" Twist Matte
Nordic Components Tactical Muzzle Brake 1/2"-28 Thread AR-15 Matte Nordic Components Tactical Muzzle Brake 1/2"-28 Thread AR-15 Matte
Yankee Hill machine diamond free float tube handguard, rifle length Machine Diamond Free Float Tube Handguard AR-15 Aluminum Matte
Del-Ton gas tube, rifle length Gas Tube Rifle AR-15 LR-308
Yankee Hill gas block, low profile, clamp-on Machine Gas Block Low Profile Clamp-On AR-15 LR-308 Standard Barrel 0.750 Inside Diameter Steel Matte
MBUS Magpul back-up sight, front MBUS® RIFLE SIGHTS - MBUS® - Magpul® Back-Up Sight – Front GEN 2
MBUS Magpul back-up sight, rear MBUS® RIFLE SIGHTS - MBUS® - Magpul® Back-Up Sight – Rear GEN 2
I plan to do some sort of optics as well, though I'm not sure what.
Thoughts and opinions on this build would be greatly appreciated, especially whether or not things will fit together.
Lower
Upper
