ant_mb
Super *********
The stock bars hurt my wrists at over 90% throttle.
Is this really a problem?
What about the width? In the overhead shot it looks like the FZ1 bars are about an inch wider on each side. Is that right? I commute and filter (lane-split) a lot and the extra width would be a pain for me.
The FZ1 bars are atleast 4 inches shorter than my old bars, and I lane split fine with the long ones.
This is what I did today:
If you fit a set of FZ1 bars, just cut an inch off each end to reduce the overall width.
How did you remove and install the grips? Did you use any adhesive? Thanks!
The clutch side grip was glued on so I used a screwdriver and a shot of silicone spray(I love that stuff) and it popped right off.
The throttle grip is actually part of the starter switch assembly and slides off with that.
I didn't use any glue putting the clutch grip back so it moves if i grab it hard, I gotta fix that. But I have bigger issues with the throttle cable at the moment.
No, I drilled the hole properly and the throttle tube itself was mounted properly.There's a locater pin on the bottom inside of the throttle assembly you either have to drill a new hole in the bar or get rid of the pin. I measured and marked where the new hole needs to go and drilled a new hole. I have not read all the posts closely so I don't know what everyone's approach is on this locater pin. Could you have missed this and that's the throttle problem?
I marked the original Bar for where the grip goes and after I removed the grip, I transferred that measurement to the new bar.
I boiled water and put the handle bar and grip in the the water and using a rag twisted the grip off. Put the grip back in the hot water and easily push the new FZ1 bar into the grip. Once cool and dried it was good as before.
I was rushing to catch a friend on a ride and forgot to plug my brake and clutch wires back in. I knew when I stopped and pulled my clutch lever and couldn't start unless in neutral that I forgot the plugs.
I really like the new riding position. Of course we all have different body ergo's so it might not suit all. I took the bike down and up Banner Grade and it felt great!
Hmmm... I seriously don't get this. You guys say you re-use all the original parts from the old handlebar. I switched to the FZ1-bar a few weeks ago (bought it directly from a Yammi dealer), and no way that I can use the stock bar-ends. They just don't fit, since there isn't any threads in the FZ1-bar...
Yeah, like, thanks. I could have worked that out myself. I'm jsut wondering if they really are that much wider or if it just looks that way. I have to replace my bars anyway after my fall so I think I'm going to go with the FZ1 bars or maybe some renthal superbike ones. Maybe I'll start a poll.
