FWIW: Old to New Tire Roll out vs Speedo Error = 2.5%
For kicks I measured the roll out distance of of NEW and USED tire to see how it impacts speedometer error during tire life. Specifically a Battlax BT023 rear tire inflated but worn into center wear bars and the new tire inflated to the same 37PSI but never ran on the bike.
Used mounted 37PSI:
Roll out: 75.5", wear passed tread bars
Tire OD: 24.03"
NEW mounted 37PSI:
Roll out: 77.375"
Tire OD: 24.63"
Tread bar depth near center: 0.22"
CALCULATED @6000RPM, 6th gear using Measured Tires:
OLD: Speed = 70.50mph, Distance = 1.175miles
NEW: Speed = 72.26mph, Distance = 1.204miles
Moral of the story: Old to new changes Speed by 2.5% or ~1.75MPH at 6000RPM. I thought it would have a greater impact based on the diameter being 0.60" different. Nope!
PS:
New unmounted BT023:
76.625" roll out
Tire OD: 24.39"
Also, 180/55/17 calculates to:
77.9" or an OD: 24.795"
TAG: JJD952 Speed Diameter
mxgolf
Motoup
Beaverton Oregon USA
SpeedoHealer would fix that correct? I have that because I changed the front sprocket. I am sure it would work for the tire change also. :thumbup:
