FS: HYPERPRO LOWERING SPRINGS FRONT AND REAR(shock included)
QwickFliCk
Manly Man Member
NY
I'm selling my hyper pro 30mm lowering spring set for $200 shipped
brand new they are $289 without the rear shock spring installed. im saving you the hassle of putting the spring on. the shock i bought on ebay for $45 used with 2k miles on it. as of now the rear shock altogether has about 4500 miles on it
heres the link from hyperpro:
http://www.wilbersusa.com/price-lists/Springs 02-12.pdf
its a direct swap from oem. im 5'6 and with it on i completely flat foot to the ground
instructions say to drop the front forks through the triple trees 5mm
heres some pics:
Sinman
MA
Hey, would this work on an 07, I am also short. Do you have all the instructions?
QwickFliCk
Manly Man Member
NY
yes it fits models '04-'09. i unfortunately dont have the instructions, buts its very straight forward.
FRONT:
remove the forks of the bike.
take off the top fork cap
remove washer and spacer
remove stock spring
drain old fork oil
refill w/ 15w fork oil (pump fork 10x to remove air bubbles)
install new spring with the more progressive side towards the fork cap
put back the spacer, washer and fork cap
install back on bike
rear:
put the bike on its center stand
remove seat, side plastics next to the seat, rear wheel and rear brake caliper
undo top and bottom bolts holding old shock. (if the bottom bolt gives u a problem coming out, give it some heat ex. butane torch)
install new shock
reinstall side plastics, seat, rear wheel and rear brake
