peppaster
Hi guys,
I put my bike on the center stand, pushed on the tail, and tried to rotate manually the front wheel, but it doesn't rotate freely. The brakes still touch the discs even without pulling the brake lever. This is confirmed by the fact that after riding the discs are kind of warm.
Do you think it is normal to have some residual braking? Do you see the same? To give you an idea I can't make more than half-wheel-revolution if try to rotate with one hand. On the contrary the rear wheel seems not to be blocked (even considering that it's loaded by the chain, etc...).
Thanks!
Thanks!
