- Joined
- Feb 7, 2009
- Messages
- 12,538
- Reaction score
- 1,185
- Points
- 113
- Location
- Cape Coral, Florida, USA
Just wanting to share a tip I recently used to diagnose a faulty coil.
The machine is a 2 stroke, "Weedeater" hedge trimmer, which I've owned 6-8 years (GHT225). Short of fuel lines its always ran flawlessly.
I was using the machine fairly hard the other day, it was very warm outside as I'm trimming away. Out of nowhere, it just starts to misfire and dies. Pull and pull, no start. 2-3 minutes later, starts like normal... Several times within an hour, does it again and again. Sounds like ignition failing. BTW, there are no #'s to test the coil..
Pull out my old timing light (clamps onto a 12 volt battery for power), the other wire of the tool clamps around the spark plug wire (between the plastic housing and the spark plug cap). Of course the motors cooled some and fires up. Turn off all the fan's in the garage and pull the trigger on the timing light, which of course lights up. Idles great, high speed is fine, light firing as expected.
After several minutes of running, getting it to that "certain" temp point (mine was at about mid throttle), it starts misfiring, the timing light firing intermediatly with the misfire. Light goes out, engine dies... Pull, no light.. Give it a couple of minutes, fire it up, timing light of course fires up...
Install a new coil (old one looked fine, flywheel to coil gap was correct).
The point,
While this isn't a MC engine, the diagnoses can be applied to any engine (including the FZ) if the ignition is in doubt/misfiring. Your able to isolate a single coil that could pass a "cold", meter test, but later act up when warm/hot or at a certain RPM.
Just an FYI to help when doing some trouble shooting for a misfire (intermediate or come and go). :thumbup:
The point,
