alexfabian
Hi Guys/Gals,
Riding to work the other day, cruising around 70mph my FZ6 2007 developed a fault, I have bullet pointed the symptoms below:
Engine Warning light on
Loosing speed to around 50mph
Bike feeling sluggish/no power available
Engine sounding rough/not able to rev correctly.
Fault code 33 on the screen.
I had the bike recovered home as I didn't want to cause any damage to the engine if the fault was in there.
Now I've got it home I have tried to find and fix the problem but unfortunately everything I've tried so far hasn't worked (listed below)
Removed the spark plugs/fitted new.
Removed the spark plugs, earthed the plug and fired, only plugs 2-3 spark, 1-4 do not.
1-4 are on the same coil so I guess that is the problem.
When I turn the ignition on there is only 12V getting to coil 2-3 not 1-4.
I have tested the starter relay and it operates correctly. Also checked the fuses and they are fine....
For some reason the power to the coil packs are not from the same wiring loom and I can't seem to find why it is not getting power to 1-4????
Any help would be greatly appreciated.
Thanks
Thanks
