Factory Labels/Stickers
Mississippi
Southaven, MS
I see that a lot of people are removing all of the Labels/Stickers off of their bike.
Can these be completely removed from the bike? Do I need to keep them somewhere else on the bike or file them with the bike paper work or something? They seem to have my vin# and other bike related stuff on them.
Wildcard
Washington, D.C.
I took off every decal except the VIN# in your first pic. You CAN take it off, but if you plan on reselling it or anything like that, I suggest you keep it on. I would just cover it with some black tape if it bothers you that much.
Mississippi
Southaven, MS
It does not necessarily bother me, it just stands out like a sore thumb. If possible, I want to clean it up a bit. They should put that thing behind the fairing or somewhere a little less obvious on the frame. I really have no plans on selling the FZ, but how would it hurt resale? If I filed it with the rest of my paperwork, I would still be able to show it?
Wildcard
Washington, D.C.
Just that the sticker with the VIN has the production date and other misc stuff on it. The only other spot for the VIN is stamped on the front of the frame. As for the swingarm sticker, take it off.
Unseen
Amsterdam, Holland
My bike doesn't have either of the stickers you show. The only stickers are on the top of the tank: unleaded fuel and read the manual.
I found those stickers really ugly and annoying, I managed to peel them off and remove the residue with some WD-40.
The stickers on the swingarm that mention the tire pression i've kept. Handy because I alway forget which pressure to use.
Mississippi
Southaven, MS
Did you throw the Vin# sticker away, or keep it also? I am thinking about taking them off and filing them with my title and all the other paperwork.
mxgolf
Motoup
Beaverton Oregon USA
An easy way to take those stickers off is with a hair dryer. Just heat them up and they should peel right off. You may still have a little sticky residue left and some rubbing alcohol will take it right off. The vin is etched on your front fork/headset mount. So you don't really need the white sticker at all.
Mississippi
Southaven, MS
Thanks,
I will give that a try before the chemicals.
Capo79
Viking spirit
Norway
Another great way to remove stickers like that, is to use olive oil. Not only does it remove the sticker, but also whatever residue that's left. :thumbup:
VEGASRIDER
100K Mile Member
RENO, NEVADA USA
I recalled there was a similar post about removing the factory stickers. One member might have mentioned about taking a digital photo of the sticker prior to removal since the sticker will tear or become unreadable after you apply sticker removal.
SirIsaac
My mind is going, Dave
Ohio, USA, planet Earth
The VIN sticker on the frame below the tank and both stickers on the swingarm can be removed essentially intact. Heat them up with a hair dryer, then use something soft-ish with a sharp edge to lift one side of the sticker, then pull carefully. (I used an expired hotel key-card on which I put a beveled edge with sandpaper for my tool.) The adhesive on the stickers will allow them to be re-stuck, so they can be relocated to less obvious locations if you like. The VIN sticker can be moved up on the frame under the tank so you don’t need to worry removing it. The other stickers can be stuck under the seat so you will have access to the useful information provided by them.
By the way, the tank badges are just stickers and can be removed also, which cleans up the look of the tank and makes washing and waxing easier. They are adhered with a layer of what appears to be double-sided foam tape, which did not survive the removal process well in my case. However, the residue can be removed from the back side of the badge, then use some double-stick foam tape to re-stick them in new locations if you like. I put mine on my swingarm:
DefyInertia
Former '04 FZ6 Rider
San Francisco, CA
Well I removed all my stickers and paid the price when i tried to register my bike in CA. I now have to bring it to the police station and have them sign-off on the bike before the DMV will register the bike (it was the frame sticker that killed me, not the swingarm or "warning" stickers).
bah!
SovietRobot
Scourge Of Humanity
Napa, CA
I bought mine used from a dealer and the only stickers left were the VIN, and the yamaha logo on the sides of the tank.
#27
Beyond the Sun....
bah!
Dude, I just read your post and almost sh** my pants:eek:I'm here in CA too, but luckily I left the frame sticker on...... wew!
What worked AMAZING for em was a steamer....if you have a "red Devil" or clothing steamer, the stickers(swingarm) just melts off, along with any "gooo".
