Error code 41
cowboybiker7
US
Code41 defines a voltage issue which indicates low voltage to the fuel pump. When this happens there is a stutter in the operation as in rough running momentarily. Charging rate from the alternator seems normal and is by meter check.found no corrosion on connections.fuel pump ohms test at spec.any previous solutions out there?
Sent from my XT1254 using Tapatalk
:welcome: to our family Buckeroo!
Error codes can come up as well as anumber of issues when there is sporatic voltage problems. Common places to look are always, though often overlooked, battery terminals, and often the kill switch is a common source of intermittent problems including stumbling.
