aca035
Update: I try new crank sensor,new valves ,tps sensor air pressure sensor,air temp sensor,new ignition coils,new sparks,new fuell pump....problem is still here :-s
any clues ?
any clues ?
With all those parts swapped and it still shows error 33?
Did you switch out the ECU?
If not, that would be the final option. After that, we go looking for a bad ground or an open wire somewhere in the wiring harness of the bike.
Because the ECU can detect the signature of the coil(s) working correctly, it has a feed back circuit that looks for an energy pattern. With a bad ground or a loose wire, both the spark and the return signature pattern could be compromised. The schematic shows a R/B Red-black wire being common to both coils. Because your error is not for both, I'd start by ohm'ing out the Orange/Black & Gray/black wires between the coils and the ECU. Use a blow dryer or a hot air gun to heat the wires and ohm them again if this oily happens when hot.
You need to inspect every connector, every wire, every place a wire could be pinched or cut for damage.
Bike "A" is the original bike with error 33. Bike "B" is new bike. Can you place all of the bike A parts on bike B and does it run properly?
There is no error 33 for now but problem is same,I changed everiithing from new bike,and voltage regulator and all sensor etc.....i already have new ecu and have old one fixed....Could problem be exhaust valve or something like that....There is a very big difrence in working between new fazer and this one.I have leo vince installed on each one.in problematic fazer there is too much bang bang from exhaust and on new one is everithing smoot and nice??
Is that it? Is that the final complaint about how it runs? It back-fires when you let off the gas (too much bang bang)?
Please Explain What it does today. What does it do right and what is wrong?
Thanks. . .
Man, that's tough to diagnose. Did you switch each part one by one, test it, switch back and try another part?
Not to be negative, but how much have you put into the "bad" bike thus far? Seems to me like it's been a substantial amount. Cost doesn't seem to be a huge issue if you were able to purchase a second bike. If it were me, I'd just put everything back onto the "good" bike and sell the other one. or is that not a possibility?
Scorp
Scorp
This is my first time on forum.
Sorry for my english.
After 42000 km and two years my Fazer Fz6 s2 on mainroad decised to have a fault code.
Famous code 33 and i'm going with only two cylinders.
Now the people is on holiday and then i'm disassembly the bike.
About the ignition coil , impedence input and output are correctly , and with ac supply , two spark plugs and two wires i see perfectly the sparks (on free air and not about pressure i know).
I'm waiting from ebay an used ignition coil .
The engine at home the day after start only at two cylinders.
I hope to resolve it !
Pay attention on that stuff on your fazers please!!!
